My home was built in 1985, we have lived here since mid-2006.
Our air handler is in our attic above our kitchen.
September 14, 2009 the a/c handler started to have leaking problems
July & into November 2011 and water damage has continued thinking its the condensation line having a leak. We picked up a shop vac and suctioned the unit from the outside about every other month. In november it damaged the ceiling with small bowing.
However we felt it was under control with the continued suctioning.
In May 2012 we had a leak again, this time the leak damaged our ceiling moreso than the last time - the ceiling bowed a lot. We sent out Service America who handles (under contract) the a/c handler.
The man took a look at it, couldn't see any water (husband suctioned the water the day before - I explaied this to him.) The tech filled up all of the liquids and said that if the leaking happens again, it could be "dirty coils" which aren't covered in our contract - $680.00 fee claiming that the fees are high due to the handler being in the attic.
The following is covered according to our contract:
Thermostat
Fuses – unit blows a fuse
Compressor
Fan Motor
Blower Assemblies
Starting & Running capacitors
High Low pressure switches
circuit boards
contactors
filter line dryer
heater
relays breaker
transformers
defrost control board
Any annual maintance isn't covered in the contract and coil cleanings are $680.00
Since this is our first home, I have no idea what our next step should be. Husband suctioned the extra water out so there is no more leaking, and the drip pan is at a tilt away from the auto-shut off value...which caused for more leaking.
But what is causing the leak we don't know.
Am I getting taken advantage of? What do you think? Any advice is helpful!
Thank you!
Thermostat
Compressor
Fan Motor
Blower Assemblies
circuit boards
contactors
filter line dryer
heater
relays breaker
transformers
Thank you!
