I purchased a Beam central vac and the manual really gets into no detail whatsoever.
Each of my inlets has one white wire. Inside of that white wire, there are 4 others (red, black, yellow, green).
I was under the assumption that all I would have to do is keep the same color pairing at each inlet and at the main power unit in order for it to work but that doesn't seem to be the case.
What I tried was pairing black/yellow and red/green at each inlet. One pairing went to one of the screws on the back of the plate. Then, I kept the same pairing at the power unit and one of each pairing went inside of the connectors there.
Any other ideas as this strategy didn't work. I can't see what the wiring is like inside of the walls so no too sure what to do.
