Hi all,
The house next door is being sold and the children gave me some of their Dad's old tools - one being a vintage Kellogg American air compressor. I don't know much about air compressors and even less about vintage ones. I'm not sure what year is was made or even what model (there are two tags with model numbers, don't know which was used to identify the compressor). Below are pics of the compressor and close-up of the major parts.
The daughter said it was running before her father passed away in 2007 but I haven't been able to start it because there is no electrical cable, it was hard-wired to a switch under his work bench. The power cable went from the switch to a box on the top left that was made by the Square D Company (see 6th image below). The motor is made by Packard. The model is S7828, 1/2 hp continuous duty, 115/230 volts, 8.2/4.4 amps, 1725 rpm. Can I use 14/2 wire to create a plug for a 115 outlet? It looks like I have the option to run 115 or 230 volts.
Here are some pics. I would appreciate any info! I would like to get this working again. It looks to be in good shape!
Front
Back
Model/Serial number on the tank
Information on Packard electrical engine
Information on the Square D electrical panel (the electrical was run into this unit)
Model/serial number on pump engine
Thanks!
Mark
Front
Back
Thanks!
Mark
