ok first I am not doing this myself but I need help because I don't want to look un knowledgeable. I have been taking down the old siding on my house and the old rotted soffits. I had a new roof put on before winter.
Now I want to have to soffits covered up but big question some tell me I should replace the wood before doing the vinyl soffits others tell me they will just put the vinyl up with out putting anything underneath.
2 questions how would you prevent bugs etc to go up in crawl space if you are just putting vinyl up and its all open above it. I am in upstate ny will that make my house colder wetter etc. in bad weather?
Next I took down the back sheating and insulated wall and am going to do this on the other 2 sides (front is brick) I wanted to do this because the insulation was not the greatest and I put up new plywood.
Question
should I tyvec house before siding if I use foam board do i skip the tyvec?
I dont want the siding to stick out much from house so will the 1/2 inch foam make it stick out much more (I dont like that look of siding covering up old stuff kinda look)
Any other pointers are really needed I don't want to do this wrong or have it done wrong
thanks much
ps its a 1 story ranch built in the 50's
Question
thanks much
