Last fall we had our roof redone, and we had the roofer install two skylights. He took care of the roof framing and skylight installation, and I'm going to do the interior work including framing the ceiling opening.
Today I cut open the ceiling to start planning the light shaft, and I have most of it figured out except for one thing. The collar ties (or ceiling joists, not sure what the correct terminology is) intersect the rafter in the middle of the skylight opening. On the right side the collar tie is on the "outside" of the rafter (from the perspective of the skylight opening), but on the left side the collar tie is inside the opening. Please take a look at the pictures for clarification.
So, I have to move the left collar tie to the other side of the rafter. My question is, do I have to install a new full-length 2x8 collar tie, spanning rafter-to-rafter? Or, can I install a partial-length of lumber, and bolt it to the existing collar-tie somewhere in the middle of the span?
There's not much room up there, and the back side of the roof is lower pitch. If I have to run a full span, it's going to be very difficult to get in that space to secure it to the back rafter.
I'm not a structural engineer, but my gut tells me that bolting should be fine because there is very little lateral force (just the weight of the ceiling). I doubt that it would sag from that. I know the collar ties also prevent the rafters from spreading, but the shear strength of 4 or 6 bolts will surely be better than the existing nails at the ends of the collar ties. So, in that case I don't think the bolts will be a weak point.
However, I can't go by my gut alone because I pulled a permit for this so it will need to pass inspection. So, is there a way to do this that would meet code? Are there requirements for the amount of overlap, number and size of bolts, etc?
Thanks for your help.
-Mark
-Mark
