Hello All,
I originally posted this in the General discussion forum. I'm thinking it may be a better fit here. I am wanting to add a screened in porch and I am having issues as to what will happen at the corner intersection indicated by the circle in the image. I'm not sure what should happen when the new roof juts out over the existing one. You will see two possible roofs I am considering, the one with the blue arrow is one possibility, this would be a metal roof. The other is the pink line directly above. Either way presents an issue where the circle is in the image. Does anyone have any insight as to what to do here?
As you can see in the images, the new porch would extend out about 4 feet and I would build this are so that deckboards sit fluch with the cement on the patio. I would then carpet it with an outdoor carpet.
