Looking for some advice on troubleshooting a small pre-lit Christmas tree.
Tree Specs
3 segments, 150 lights with (assuming) 50 lights per segment
Top segment has only a male plug, middle and bottom have male and female
Bulbs are 2.5V, .425w
Each segment is wired in some type of parallel configuration
I assembled the tree as normal, and it was completely dead. I plugged in each segment momentarily, and all three were dead. I noticed that on the top segment, there were a number of bulbs burnt out (noticeable black residue on the bulb). I purchased two new sets of lights that met the same specifications for voltage and wattage, and replaced all the bulbs on that segment including the fuse bulb (was not soldered), using the existing bulb bases and the new donor bulbs. This fixed the top segment.
I did the same thing with the middle segment, but it was still dead. I checked the fuses by swapping the fuses from the top segment, still dead. I swapped the fuses back, and plugged the top segment into the middle section, and it illuminated, so I am getting voltage through the whole string. I double checked to make sure all the bulbs were seated correctly.
I have a BulbKeeper Pro, so I plugged a socket in and tried the shunt repair, which also did not work. Before I start tracing down broken wires or sockets, I'd like to clear up how exactly this tree is configured, as I've never run across this wiring configuration before.
The attached photo shows the first socket after the male plug:
A: Originates from the small "wing" off to the side of the bulb, continues on through the bulb series, but does not connect to any sockets
B: Originates at this socket, connects to next socket in line
C: Originates at the male plug
D: Originates at the male plug, connects to the last socket in the series, which mirrors this socket, except it does not have a fuse bulb
E: Originates at this socket, connects to female plug
My two questions are:
1. What type of wiring setup is this? Some type of dual-parallel?
2. Given what I have replaced/tested already, am I down to testing wires/sockets?
Tree Specs
