Hi,
We tore down our office to the studs to replace insulation and repair damage. We wanted to add a ceiling light, and we have an existing light switch that powers an outlet, so we ran a wire from the ceiling to the switch. New walls are now up and painted. Now, I know this was wrong, and we should've run the wire to the outlet instead. At the switch, there are black hot and white neutral wires coming in, and both are connected to the switch (no ground - 60s house). I understand that we would've needed the neutral to not be connected to the switch so we could pigtail that with the neutral from the new ceiling wire to have both the outlet and new light work.
We don't care about the outlet anymore since there are 2 others and it's a small room, so we have no problem covering it up. Does that make it possible to wire the new wire from the ceiling into the switch with the existing wires from the outlet to make the light work? I would think there's a way to tap into that power, even if it's at the expense of losing the outlet. What would that wiring look like at the outlet box and the switch box?
I'm not sure if I explained this well, so please feel free to ask additional questions.
Thanks so much for your help!
