I am about to attempt to fix a leaking faucet on a bath fixture. I have attached two pictures. I will not be able to access the valve from underneath without removing a panel that is glued on to the tub so I want to avoid that option. This leaves me only working from the top. I have messed with a few of these over the years and sometimes I have had good luck, sometimes not. After working with plumbing for 50 years or so I know the risks of making something worse instead of letting it be but we are selling he house and I need to fix this or at least make an attempt. The water is leaking out from around the stem when you turn on the cold water. One question I have is whether you think I can remove that valve from the top without holding it from underneath? My guess is that in any event its going to be hard to turn. The water here is very hard and I'm sure that calcium deposits have had something to do with causing this to leak. Any help would be appreciated. Thanks.
