1 - 6 of 6 Posts
Help with inexpensive & quick way to fix crack in wall
Help with inexpensive & quick way to fix crack in wall. The crack in the wall is due to rain damage from 5+ years ago. The wall is white & I’m thinking I would be okay just covering it with spackle or caulking. Any ideas?
retired painter
Re: Help with inexpensive & quick way to fix crack in wall
Is this drywall or plaster?
You might get away with scratching out the crack and filling it with Durabond. If you use regular pre mixed joint compound you'll need to tape/finish it like a drywall joint.
Super Moderator
A few more details would help. A picture would be best. What type of wall? Is the water leak fixed? How big is the crack?
1 - 6 of 6 Posts
