I am trying to compare two tools: Kobalt Impact Wrench and Craftsman Impact Wrench. I need help understanding why one is better over the other.
Kobalt ..............................................................................Craftsman
Air Pressure 90psi ............................................................Max Air Pressure 90psi
Ave Air consumption 4 CFM ............................................Ave Air Consumption 4.4 SCFM
Max Torque 360 ft. lbs .....................................................Max Torque 300 ft lbs
Free speed 7000 rpm +/- 10%.......................................... Free Speed 7500 rpm
Frustrating thing is one is measured in CFM and the other is SCFM. Max torque tells me to go with the Kobalt but the Ave Air Consumption on the Craftsman is higher, but again the units aren’t the same CFM vs SCFM
The other tool is the Ratchet Air Wrench
Kobalt ...............................................................................Craftsman
Air Pressure 90psi ..............................................................Max Air Pressure 90psi
Ave Air consumption 3.5 CFM ...........................................Ave Air Consumption 4.9 SCFM
Max Torque 60 ft. lbs .........................................................Max Torque 45 ft lbs
Free speed 160 rpm +/- 10%.............................................. Free Speed 150 rpm
Here again torque much better on Kobalt but Ave Air Consumption on the Craftsman is higher, was thinking that ave air consumption meant it was more powerful. Don’t know, very confused. Please help.
