Hi, hoping for some advice or ideas here...
Someone had covered my fireplace with floor tile (don't ask), and after removing I found the original brick below. No problems there…I already figured it would be unusable: My plan was always to just tile around the opening and build a decorative wood frame around the perimeter.
The problem is...the brick is somewhat detached from the wall: If you grab onto the top, you can rock/pull it forward a bit…it basically moves as one large piece. To be fair, it takes a bit of muscle, but it can still be moved.
I know zero about brickwork or fireplace construction, but it appears it’s just plaster wall behind it…and I honestly don’t see how or where this was ever even attached to it. Not sure if it’s normal that it would just be freestanding like this??
Anyhow, in order to tile and re-do as described above, I feel like I need to properly secure things here. Options?
Thanks so much for reading.
Obviously the safest/smartest thing would be to remove all the brick and rebuild it…which, well...seems like a nightmare.
Cut one large piece of cementboard to cover the front and drive some 8” bolts through to bolt the whole thing to the wall. This seems like a good idea and would also provide a proper backing to tile, but if it’s plaster behind there, I'd definitely have to find the studs.
Bolt some metal retaining straps across the face? (Although...I just tried to see if there are studs at the very far left and right, and it's hard to tell)
Tile over it as-is and call it a day? The previous floor tile was no doubt helping to hold things together, but obviously this isn’t the smartest route to go.
Other? :/
