Hello everyone I am at a sticking point on troubleshooting my AC problem and was hoping for some input. I have a older Lennox 2.5 ton central air unit connected to a Pulse g14 furnace and the other day when I went to turn it on for the first time this year it came on fan but the air flow from the vents was not very good.
I ended up taking the blower out and cleaned the cage and the bottom of the heat exchanger(they were both pretty dirty as the previous owner had let the filter get clogged to the point that it had popped off). This increased the airflow from the registers quite a bit and yesterday it was about 87F out and I had the AC set to 72 to see how it would do. It came on about 11:30am and ran until I went to bed at which point it was now 75 inside.
So I get up around midnight and notice its now at 73 and still running but the air from the registers is low again so I figure it must be iced up. I went down and removed the panels to view the evaporator and sure enough it was iced up but not uniformly. the upper half of one side was iced while the bottom was not and the left and right sections in the middle on the other side were frozen but the rest was not.
Moving on today it had thawed and I turned it on again and checked out the icing again when it started and the spots that are not freezing up are not even cold to the touch. I can run my hand about an inch above the coil all over and feel warm and cold spots. What can cause this knowing that the airflow is fine across the coil??? Low R22? Compressor going out? Any input woul dbe much appreciated. I have someone coming out to check it out tomorrow but I like to be as much informed as I can be. Thanks!
