Hello all I'm having a problem with my furnace.When you first turn it in it will blow warm for 1-2 minutes then cold&the only way to get it to blow warm again is if I trip the breaker then it will blow warm for another minute or two.Th unit is only about 5 years old&I never had this problem before.I had 2 hvac guys come &neither one of them could fix it one said I needed a bigger cold air return...which the vent has always been the same size,so I cut into my hardwood floors&same thing.Then the other guy said I needed a hole in the duct work.
I know it isn't because of how cold it is outside because it will do it nomatter if its 50 out or 5.Well I live out in the boonies &don't have many options on people to come [email protected] it got any ideas?Btw this furnace dosnt have a filter they don't use one&Im a 100% sure of that.
