I'm looking at a dryer vent that passes through attic space over a garage to a side vent. The vent is rigid metal, approximately 20-25 feet long with one 90 angle at the dryer outlet. There are 3 rigid sections, followed by a short flexible duct section attached to the exterior vent. There is duct tape over the seams.
The problem is that water is dripping from the seams. Presumably this is because of condensation inside the duct in the cold weather we're having here in NC. There is no insulation. The duct run looks straight, but I don't know if there's a slope to to it. It's kind of hard to tell over the long run of it.
What is the best option here? Is it possible this could be solved by proper sloping and connecting the ductwork with overlapping connections in the right direction? Would it simply be best to vent straight up through the roof instead?
