My Honeywell humidifier burned out the outlet, probably because I had that and my condensate pump on one outlet with a splitter. The plug on the humidifier is burned. Is it easy enough to swap it out or should I get an electrician? Operates at 120 VAC at full load, pulling 12 amps. Thanks.
