I am in the process of finishing my basement and am beginning the electrical portion of the project. Given what I want to accomplish I've checked around different sites and reviewed my wiring book and seem to find several different answers so I thought I would post my specific situation and maybe with your help get some clarity on how to move forward.
Current configuration - Power enters a double switch box, wire is 14/3. One switch is 3 way that handles the stairway light. The other switch controls 4 light fixtures in the basement. I pulled down the first light of the run to see how it was wired in. I found two sets of 14/3 wires entering the light box. One went directly into the smoke detector about a foot away from the light fixture. The second 14/3 -The doorbell transformer is also attached to the first light fixture and tied into the second 14/3 cable. That first light fixture has the red wire and neutral attached to it. The second light is branched and has a black hot and neutral (no ground) traveling to it through conduit. The third and fourth light are on a second branch and wired in the same manner.
What I want to do - Have the first and existing switch manage 5 primary light fixtures in the room, add second switch to control a hallway light, add a third switch to control a florescent light in a walk in closet, and finally adding a fourth switch to control a storage room light.
What would be the best way to wire this configuration on the current circuit the lighting is on (removing the original 4 fixtures of course). I'm essentially starting from the beginning aside from the 14/3 that lands at the first light which is the same location I want the first new fixture to go.
I appreciate your help and input.
