The answer depends on where the power is supplied to for those lights.
If the power is to the light fixtures and a switch wire is run to the switch box, continue the power from the light fixture.
If the power is brought in to the switch box and then to the fixture, run power from the switch is possible.
But I am a Carpenter. An Electrician should be along shortly.
