I'm looking for help wiring new lights in my basement. The room is long so I am installing 12 recessed lights in the ceiling. I want 1/2 the room to be controlled using 3 way switches and the other 1/2 to use a single pole switch. Switch 1 & switch 2 are the 3 way switches controlling cans 1 - 6. Cans 7 - 12 will be controlled by switch 3. The live feed currently goes into switch 1. My initial thought is that switch 1 leads to can 1 and to switch 2. Switch 3 leads to can 7. See below:
Feed to S1 is 12-2 romex cable. S1 to S2 is 12-3 romex cable. All other wiring is currently 12-2 romex cable. S2 & S3 are both dimmer switches to control their respective halves of the room.
Now, when S1 is off, toggling S2 has no effect nor does S3. If S1 is on and S2 is off, all lights are off. If S1 & S2 are on but S3 is off, cans 1 - 6 are on, 7 - 12 are off. If all 3 switches are on, all 12 cans are on. I think I understand the issue, but I want to know if its even possible. Any help and suggestions would be appreciated. Thank you.
Code:
feed
s1-------------s2-------s3
c1-----c3------c5 c7------c9-----c11
c2 c4 c6 c8 c10 c12
