We've been doing small DIY upgrades on our home and today my husband installed a Honeywell RTH6350 t-stat. It was to replace our much older, working one.
All power was turned off before he started and the install seemed to go well even with that pesky B wire that was no longer needed. Every wire appears to be in it's rightful spot. We have checked and double checked. We turned the power back on, programmed the t-stat to our specific needs and...no heat. The furnace never fired.
The central A/C unit and fans work fine. Our furnace is a ThermoPride fueled by oil. The entire unit is quiet. Like I said, the fan works fine. There's just no heat. I did press the red re-set button twice, there was about 1 hours between tries, and nothing. The two little yellow lights located near the re-set briefly light up when pressing the re-set, but they quickly go off and the furnace remains quiet.
How bad have we screwed up our furnace? What can we do to try and fix it? I'm pretty sure it's still under warranty, but would that cover something like this? Should we just leave it alone and call our HVAC people tomorrow?
Is it some kind of fried fuse or circuit board?
