Help Repairing Brick Facade
681 Views 1 Reply 2 Participants Last post by  Tscarborough
Hi All,
We have brick facade on the front of our house and it looks like the mortar holding a couple of the bricks has come loose.
I'm wondering what I use to repair this, and if I'm planning to go about this the right way.
My plan is to just remove all of the loose mortar, and any bricks that come out with it (looks like just 1), and then replace the bricks and mortar.
Is this the correct approach? What mortar should I use?
Thanks,
Don
1 - 2 of 2 Posts
If you do not fix the issue causing the problem, it will be a short term fix. That is the correct method to repair it once you fix what is making it happen though.
1 - 2 of 2 Posts
