Howdy ADuncan81,
It sure looks like you've got your work cut out for you. All the ideas you listed like the sloping and sand are sound paving practices. I didn't notice the depth of the paver base was listed. You need a solid foundation to keep things from shifting. The only thing I do not think will work is the adhesive idea. If you have an edging/border that is anchored in the ground the simple physics shows it will stay put. Weather has a way of destroying shortcuts. Other than that, as far as I can tell it would work well.
Hope this helps you in your project,
Coach Dave
Coach Dave
