Do you have the original cans of paint in you possession? Are they a good brand or cut rate stuff? Did he spray or brush?
If you still have the original cans. I would strip a small section down close to the ground. Apply the same treatment he claims to have provided and see if the results match.
If it is cut rate paint if often does not have the same quantity of pigment solids as higher quality stuff. If he sprayed he may have over-thinned.
If it is a quality paint company, contact them and see if they will send out a rep. to look at the paint. They often have field guys who can tell good from bad workmanship and may stand with you.
