Hello, I am hoping someone here can help me. I was looking online for a HVAC forum that might be able to help me with my issue and I found this!
I had a new furnace and Central Air installed about 3-4 years ago now. In the last couple days, it hasn't been cooling as well as it used to. I've been noticing that it just keeps running and running. Last night for example, I had set it to 74 just to try and get it to run less. The temperature outside was about 65 or so by that time. It's been really hot and humid the last few days. But even with that, such a new unit shouldn't have to keep running and running, should it?
One thing I did to today was replace the air filter. It's been just over 6 months since I've replaced it. But that doesn't seem to have helped.
I also noticed that the A/C unit outside was covered with junk between the slats. I've never honestly thought about cleaning those out. So, I took a vacuum and an air hose and cleaned out in between the slats and even inside as best as I could. It's much better than it was. I can actually see the metal inside when I look between the slats now!
However, it still doesn't seem to be running as cool as it should be. Granted, today is another muggy, hot day. But I can't seem to get the inside temperature to go below 75-74 now. Currently the outside temperature is 77 and semi sunny.
One thing I have noticed is that when I look at the physical A/C pieces down in the basement (sorry, I have no idea of the proper terminology); there are two pieces that are joined by a flexible fabric. It's the piece that sits on top of the furnace. If I remember right the first (bottom) part holds some triangular shape thing that does the actual cooling.
Well, the bottom piece is extremely cold to the touch. But the piece above it is not so cold. It is cold, but nowhere near the coldness of the bottom piece. There is also a lot of liquid (condensation) accumulating on the one side of the bottom piece. I've linked photos for you to see to maybe help with what I'm talking about here.
My Central Air unit is made by Trane if that helps any. The company that installed it is closed now. It's Saturday and they close at 3. I really don't want to call it an emergency and have to pay a ton of money if there is something I can do myself or wait until early next week for them to come out and look at it if it is something major.
I hope I explained my issue well and thanks in advance for any help!
Picture of both the top and bottom ducting that sits above the furnace:
Picture of the side of the bottom piece with all the liquid:
