Hi all,
I'm installing a whole house fan that has two separate motors that are suppose to be plugged into two outlets. Below is the diagram I created of how I think the wires are suppose to run. Does this look ok? For some reason the instructions doesn't show the white wire from the timer connected to the common white wires. Should I connect it to the common just like in my diagram or leave it unconnected?
Thank you kindly!
Thank you kindly!
