I need some advice on what my next best option is to fixing the problem I created. An explanation on what I did. First, I put down 1/4" cork, then stapled down radiant heat mat, and then poured self leveling concrete over it. The problem I created was that I saw a few spots were the radiant heat mat was showing through the newly poured concrete and I added more of it to this area. Well, now I have a "bump" in the middle of the bathroom floor--maybe a 1/4" higher than the other parts of the bathroom:furious:. I can think of 2 options:
1. Add more self leveling concrete to the lower areas and I've already painted/marked these areas...you should see it the picture.
2. Try and grind down the bump
What should I do? What would work better? If someone thinks grinding it down any recommendations on a "grinder".
***Oh yeah, one more problem I have to put tile on top of this concrete floor. So now I'm concerned with how high this floor will turn out. I do plan on using real thick carpet joining the tile...but I don't want a significant step upwards.
Thoughts???
Thoughts???
