I have a house with a hip roof. my garage is a 20x20 2 car attached. there is a bedroom and half bath behind it, and even though it is attached it kinda has it's own roof.
there is a HUGE space above the garage that i really want to use. it looks to my novice eye that the builder meant for it to be used, since directly above the garage they used 2 x 10's set 16"OC, and stepped it down to 2 x 6's above the back room
See picts below. The first pict is looking toward the side exterior wall ( the rear of the house is to the left, the front of garage is toward right)
the distance from the knee-wall to were the joists step down to 2 x6 is about 15'. There is about 77-1/2" inches of height between the top of the 2 x 10's and the bottom of the parralel rafters
Second pict shows the unisulated floor area is over garage, the area with the loose cellulose insulation on the right is the back bedroom. The area behind the fiberglass insulated wall is the master beedroom
what I'd really like to do is put a door in from the master bedroom, and frame in a a walk-in closet that would go about 7' deep and 15' wide and then a seperate "rough" storage area in the remaining 13'x15' feet
any thoughts? concerns? Suggestions
The opening appears to be have a 54" roughed-in opening for a pull down stairs
