My dishwasher (Whirlpool Gold Quite Partner III) has a "slight" leak out the door. When I look at the bottom of the door, I see about 5 holes which appear to be there as part of the manufacturing process.
The leak looks to be coming from the middle hole. Anyhow, I concluded I should be able to take the door pannel off and easily see where the leak was coming from. No such joy. I looked all around the inside of the door and can't seem to find anything.
I messed with the little flapper seal up by the air vent thinking that may be loose, and looked for leaks around the detergent area- nothing overly obvious to me.
I put it all together and ran one cycle with no leak. I ran another cycle yesterday and now the same pesky leak is back .
Please send some advice my way!
Thank you!
Thank you!
