1 - 7 of 7 Posts
The window sash balancer in one of my windows isn't working, and the problem is that there's a clip missing that screws into the sash and sticks out into the spring in the frame.
This is a picture of the clip that I do have, but I'm having trouble tracking one down, partially because I don't know what it's called. Anyone know the name of the part or where I might find a new one?
Thanks!
Will
retired framer
It is hard to believe a piece like that could go missing, have you taken everything apart looking for it.
J is correct , it is a pivot bar . They are easily replacable .
HOWEVER..... are you sure it isn't still in the window sash ???
They are usually inserted into a channel in the bottom of the sash . This channel is (again usually) part of the extrusion that runs the entire length of the bottom piece . If the retaining screw fell out it may have worked itself away from position .
I'd lay a short board on the floor & gently bounce the sash (on the side ) on it to see if it pops out or at least becomes visible .
1 - 7 of 7 Posts
