Photo #1, 2 This is the inside of our front door. The miniblinds are 84" long, though they only drop about 72 inches to the bottom of the window.
Photo #3 The problem is when the door is opened at a normal speed or fast, the blinds swing out to the right, and then swing back and end up over the handle,
If you move the door slowly, the blinds don't swing out so much, and the blinds stay inside the door handle, where they belong.
So I want to find a way to keep the blinds inside the handle. Not sure if it should be something like a mini-shelf that the bottom of the blinds can rest in. Or something along the sides to keep it from swaying? Or some kind of bracket? Or what else?
The blinds are in the down position most of the year, as the door faces south. Not good in the hot summer in Arizona. But we move them up and down in the cool winter.
This is a foam-core steel door, so I'd rather not do a lot of trial and error and not need to drill too many holes in it that might be hard to patch at some point in the future.
