1 - 7 of 7 Posts
Hi Everyone,
I'm new to the forum but I check it pretty often.
I own my first home in Baltimore City and am currently remodeling the upstairs bedrooms. The house is very old and the electrical system needed to be replaced, however the walls are mainly plaster/lath so I decided to rip the ceiling down (ugh.), tear out the old wiring, and re-frame everything for new drywall.
I also decided to re-frame for the entry door to be relocated because the bedroom next to the one I'm referring to is currently a walk-through and by moving the entry door over I can now convert the walk-through bedroom to a third small bedroom should I decide to rent the place out.
However, now that I've relocated the entry door to the bedroom, I'm stumped as to what I should do for closet space.
Here is the current (rough) layout of the room:
The measurements I made are how much space I would have including framing and drywall.
My first thought is to put a set of shelves in the 15" area and 2 hang rods in the 45" area. So when the door opens (in) there would be a wall on each side (one of which would have the light switch) coming out about 1.5 feet (which is probably how deep I would make each side closet).
Is this my best option or what would you do if you were me? I'm looking for some other ideas before I start framing out the new closets so any input would be appreciated. Thanks!
Stuck in the 70's
I know this isn't what you asked, but if you are doing this to possible rent out later are you sure both rooms will qualify as bedrooms?
Not an expert, but my understanding is many/most municipalities have requirements such as square footage, closet, egress window etc. before you can claim a room as a bedroom. You might check into the requirements before you get started.
Discussion Starter #3
Not an expert, but my understanding is many/most municipalities have requirements such as square footage, closet, egress window etc. before you can claim a room as a bedroom. I'd make sure both qualify before you get started.
I've asked a local carpenter and from what I understand, because the walk-through bedroom does have a window, it would qualify (I'm assuming that is the one you're questioning) as a bedroom. Actually, it was listed on realtor listings as a third bedroom when I bought the place
Also, just to clarify, I'm not planning on enclosing that bedroom permanently. It will have a temporary wall separating it from the hallway or it could be opened up to be what it was originally. I guess you could call it a hybrid.
what is the overall width of the room??
I can see that it is 14' long, but a guess might be 92" wide (assuming a 32" door at your entry.)
a couple of initial thoughts:
1) you could by a wardrobe. these are self contained, have doors and can be moved if the lay out of the room changes.
2) is there a room to the right of this one? if so, does it have a closet?? It is common to see closets on adjoining rooms split the difference of the joining wall (i have attached a very simple example.) you can then make the closets as big as the wall will permit.
make sure that the dividing wall is not load bearing, if it is, you could basically frame in a header that would span the width of the closets (just like a door or window) and then frame in your closets...
i hope this is helpful
rod
Banned
At 18" deep your closet will not be deep enough
I had one at my last house that wasn't deep enough
I looked at a new house & the rough framed closet was 25" deep
Subtract 1" for drywall & you end up with 24" depth
Discussion Starter #6
rod
Sorry, I should have clarified.
The entry door is on the wall that separates the two bedrooms.
The wall on the right (of the diagram) is a brick wall with another house next to it (Balmur city row homes) which I framed over for drywall.
The overall width is 9.5 feet.
overall layout of the floor
an overall layout of the floor would be helpful to get a complete idea of what you have to work with..
I am in the process of designing part of my second floor and i intend on removing the interior walls completely in order to get the most out of wasted space etc...
good luck
rod
1 - 7 of 7 Posts
