I am returning to a project I started last summer. I finished about 2/3 on the interior part of the project. I worked at it for a couple months and learned quite a bit as I went.
My biggest problem was the speed of my progress, it went slow, very slow.
I am considering buying a sprayer in order to complete the project over the next 6 weeks.
Along with finishing a couple rooms of the interior, I am also going to be painting the exterior.
the home is approx 7000 sq/ft, single story.
For the interior I have to do the following:
-in the master bedroom: one bathroom & two closets (walls&ceilings)
-bedroom3: bedroom, closet & bath
-hall restroom
-repaint a ceiling in a large sitting room, that I painted previously, but the paint looks uneven.
the ceilings in the home are tall, 10-12 feet so I will need wand attachments for the sprayer to help with this.
exterior:
-the front wall is stone only the tudor style points on the roof need painted
- the other 3 walls need painted these walls are rough stucco.
- two large 2 car garages, interior walls are rough stucco.
- **I also plan on applying an epoxy type garage floor, but not sure if a sprayer would handle that load.
this is a large home, and I've brushed & rolled what I've finished last fall. but that was very time consuming. these rooms have so many corners due to drop ceilings, crown molding, shelving in closets. that it would take forever to cut in the corners by brush, let alone apply a coat with the roller.
I know there will be a problem with overspray if I go with a sprayer, but I am willing to prep for that. I've already spent allot of time prepping when I was rolling/brush painting to prevent splatter from falling on wood trim, carpeting, marble, furniture, etc.. the little bit of extra time on top of that needed to seal off any openings for spraying will be worth it. I feel the time saved by spraying will pay for the cost of any sprayer.
I checked the rental rates in my area and I don't think it's cost effective for me to rent one, it would be $780/month or $75/day to rent an Airlessco Model: LP540. not counting other accessories I may want/need. I would rather buy one and at least have something for the money spent, and possibly for future use or even selling the unit.
I am considering buying/ordering a sprayer & accessories. I will need it to apply primer & paint on the interior as well as the exterior.
My first consideration was the Magnum X7 from H.D.
but now I am wondering if something like the Graco 395 ultra would be a better option for my needs.
any advice?
Thank You.
-hall restroom
exterior:
any advice?
Thank You.
