I hope I can get a couple suggestions. I am putting in a patio that is sloped away from the house and really want to put a curved sitting wall, but the slope would bottom out at the bottom of the "arch" of the wall. The patio is somewhat above ground grade so I was thinking of a way to allow the water to run through the wall. Any suggestions out there and/or products that would allow a clean look?
Thanks!
retired framer
The patio is built out of pavers and the wall is built from 3" wall blocks. I'm in between EPHenry and Techo-Bloc products....haven't pulled the trigger on them yet.
Can you just leave some spaces in the first row. Maybe some pros will be along with some good suggestions.
