Older gfic units tend to not be as reliable in damp locations. Some are for interior use only. If it is a habitual problem I would replace the unit.
The GFI is in one of her bathrooms and controls 3 outside outlets which appear to be pretty well protected from water. The gfi will reset after the rain is over for about an hour.
Thanks
That's the best answer. Turn off the breaker, remove outlet covers, pull receptacles, inspect for moisture. Upgrade the covers if that would help.Pull the outside receptacles and see which one is getting wet.
Ground faults are when current leaks from the active wires to safety ground, to earth, through a human, etc.I'm a cabinet maker by trade... When it rains, her "ground fault indicator" trips but then can be reset after the rain. I ran the question on Google and it seems to be a common problem.
Outdoor Romex is usually grey and has a different cover layout. Instead of one outer case that can be slit and cut and pulled off. The outdoor wire has the case cover all 3 wires completely and takes more effort to unsheath. It would be hard to tell by looking in the junction box if you can't inspect the sheath well.How would an electrician determine if the Romex was for indoor or outdoor use? Is there a different color? I think you have keyed on the problem since at some time a downline receptacle was put in and the cable is visible from the GFI controlled box.
Amelia.
Amelia.
