I"m having an issue with kitchen lights. I'm in an apartment unit that used a light fixture with 2 t8 flourescnet bulbs (with electronic intant start ballast). I want to replace them with led bulbs. I removed the ballast and direct wired the tombstones (shunted), and the lights arn't coming on.
Heres the bulb im trying to install
www.ledmyplace.com
heres the bulbs currently in the fixture:
https://www.amazon.com/Sylvania-21777-FO32-830-ECO/dp/B07R623YPK
attached is the direct wire config: 2 Blue wires on hot (black) one red wire on neutral (white)
the tombstones, being shunted, and 1 blue wire coming from each Left tombstone, whereas the right side has a red wire coming from one tombstone, but a blue with black striped wire connecting the 2.
T8 4ft 22W LED Tube Light, 2-Row LED Tube, 6500K Clear Dual Ended Power
LEDMyplace presents a 22-watt two-row dual-ended LED tube that has a clear housing. This four feet LED tube is energy efficient and is a perfect retrofit for T8, T10, or T12 tubes. Having a long life this tube will run for more than 50,000 hours which means that you won't have to worry about...
