Hello all, this is my first post on the forum glad to be here!
I bought my house in July 2012 in Buffalo NY. Its a small brick ranch with what could be a nice basement if not for the mold problem I'm having. When I first moved in there was mold/mildew on the masonry walls so I looked up what to do and I scraped every inch of mold off the walls with a wire brush and scrubbed them with a bleach and water mix. I wanted to use Drylok to seal the walls but they've been painted numerous times already. I ended up using Kilz 2 which is supposed to prevent mold and mildew growth.
So, next I wanted to know what was causing the mold and found out it was a humidity problem. So I went out and purchased a dehumidifier and kept the humidity below 50. Now, its winter, the relative humidity down there is about 30-40 each day and I was told mold cannot grow in these conditions, however.......its back. on all 4 walls. What is going on here? I'd like to partially finish this basement and make it livable since my house is very small and this is the biggest space. But this mold issue needs to be solved. Any tips on what I can do? Calling in a specialist is probably not an option for me as I'm on a very strict budget.
Thanks for the help/advice, much appreciated! :thumbup:
