Hello All,
I am planning on replacing a approx. 50lb chandelier in a two story foyer with a
130 lb chandelier.The home is newer construction 2x4 "truss" system in attic space. I have purchased the Westinghouse Hercules j-box system rated to handle up to 800lbs. Fixtures to replace the existing one since it is not strong enough.I have also purchased a worm gear manual winch 2000lb rating which I plan to use to lower the existing fixture and "raise" the replacement. I have attic access from above which is where I plan to mount the winch temporarily to get the job done , a 14' step ladder (ceiling height is 17'6")will give me access to the ceiling for the wiring/j-box connections...I plan to cut a small access hole alongside the existing j-box hole in the drywall to allow the hook /cable to drop down to first floor. Anyone here have any advice from experiences doing this?
