1 - 9 of 9 Posts
I am at a loss - not even sure where to start
It appears one of the heating duct work runs has separated somewhere under the floor on the second story. Heat is reaching a few rooms - however not to two of the bedrooms. It is so cold in these rooms I want to close the doors. Anyone with any ideas would sure help me out.
Maybe you have a damper in the system that worked it's way shut somehow. If it really disconnected then shutting registers in the working rooms will just force more heat into your ceiling cavity. Maybe you can rent a camera like what plumbers use to figure it out.
Does your cell phone have a camera ? Is it capable of taking video ?
Upstream of the problem . Remove a grill / register . Turn the camera on , recording video & stick it in the duct and shoot a few minutes of video , slowly moving it around to catch the area you think has the problem .
Repeat down stream of the problem , pointing in the opposite direction .
Let us know what you find . Post the videos to some where like DropBox & post links .
God bless
Wyr
1 - 9 of 9 Posts
