Need some advice,
The water table under my newly constructed home is approx. 8in. below the basement floor. I have taken care of this issue with a gravity drain. Though I have been thinking of another way to remove this approx. 1-2 gals/min water. Would it be possible to grundfous pump this water through pex, wrapped around both hot water tank pvc exhaust and forced air pvc exhaust to increase temp, then exit home to be routed under the sidewalk (not yet in) with an approx. length of 70ft. Since this water has to leave the sump anyway, I would then dump it into a stream 40ft from where the side walk would end. If the water temp could rise to at least70+ deg. Would it be enough to melt the snow under the sidewalk? Erie PA
