soaker tub and backsplash, kitchen backsplash, Var fixes around the house.
Hi,
We will be updating our Heat pump soon, it is 16 yrs old and not working properly. There is a lot of info here, so let's just assume it needs to go.
I Have done research and maybe am not asking the right questions, it is still quite difficult to decide. I could really use some good pointers to help me make the right or "best" decisions. I have done a lot of reading.
I have had several estimates, each guy tells me something different... some are quick to pick a type, others are not forthcoming. I Have seen from 1700 to 10K estimates. (yes seriously) Someone is bullpooping here.
I would like to learn how to figure it all out myself, but realize it can actually be quite complicated. Hoping you will read on, I will include some details and images.
Climate and Condo.
I live in Charlotte NC, it gets hot throughout the year... 100s in the summer, a few days below zero in the winter and has been warm in the winter from 32 to 70+ on any given day. Some snow 1x-3x and not much... we get ice.
The humidity really sucks here. My current unit had trouble getting it out of the air until it started slowing down... at which point it got a little better, However the dripping condensation would have eaten a hole through the floor of the return had I not caught and put a pan under it over the last year. (drips straight down.)
some of metal on the 4-5 year old evaporator coil has completely rusted away. Much rust in there.
Our condo is 1100 sq ft.
Second floor
12' vaulted ceilings in most rooms (attic above)
7 Registers (not including small one above the handler.)
5 runs I think.
Insulation in ceiling with vapor barrier on sheetrock.
Same for sides and the neighbor below in plenum.
Current heat pump: 2004 (16 year old carrier) R22.
I cannot find the Kilowatt rating on the condenser or the handler.
3 guys told me I have a 2-ton 12-14 seer single stage Heatpump
which is what I have been told in the past.
1 guy told me I have a 1.5 Ton single stage heatpump.
attached are some pics, the names show where they are from. I will tac one reply with an internal view.
Thought I was looking at a (410A)
Single stage 2 ton 16 seer or a
Two Stage 2 ton 16 seer
Now one guy says a 1.5 ton with variable speed fan in handler???
I know a few things: (aside from I don't know enough)
It must be sized like Goldy locks... not to big, not too small or it will not work right! and must be 410A.
Supposedly Variable 2 stage will take more humidity out of the air by running slower and more efficiently, but if it breaks is much more expensive to fix.
Single stage will pull the humidity out if it is working right...
Seriously Humidity kills us.
We will probably get some form of UV scrubber.
We have other major expenses and this is going to make life hard for a while.
Gee, I wrote a book! If you are still here, enjoy the pics.
Concerns:
I never want to worry about it dripping into the return and eating a hole in my floor and the neighbors ceiling.
I would like it to not rust out.
Seriously HATE humidity. We get mold out of the air here. Cannot have it.
The long tall skinny label is from the outside condenser.
Climate and Condo.
Second floor
5 runs I think.
Concerns:
