Gentlemen,
I have a 4 year old heat pump that I am trying to troubleshoot. I came down stairs this morning to find that my heater was only producing room temperature air. I went through the basic troubleshooting that I am capable of, which consists of the following.
-Inside blower does come on.
-Inside condenser in the air handler is not warm to touch. (Should it be?)
-Outside HP unit fan and compressor come on.
-Larger copper line (insulated with foam rubber) gets very warm to touch.
-Smaller copper line (uninsulated) is only slightly warm.
-There is no ice, snow, debris, or blockage of any kind on the outside unit.
I am pretty sure that my thermostat has been improperly configured for an unknown amout of time to use a single stage heat pump. I have heating coils inside the air handler and when I reset the thermostat and reprogrammed for a 2 stage heat pump, I started getting hot air. Now my thermostat has an AUX indicator on the display, which I have never noticed before.
How can I be sure that my system is operating properly? I know that the auxiliary heat uses about 3x the energy that the heat pump uses, so I'm worried about it having to run in AUX mode.
This is a Braeburn 5300 thermostat and a Nordyne ft4be-036k 14 seer heat pump. T-stat is set on 72.
