I bought a new construction home back in July 2010. House has Trane heat pump with two zones. Trane 4TEC3F24B100A air handler with BAYHTR1008+++ auxiliary heat (according to air handler label). Both thermostats were TH3110D1008, but I replaced the main floor thermostat with a RTH7600D 7-day programmable touch-screen thermostat. It's all controlled by a Aprilaire 6303 zoned comfort control system.
I never really paid any attention to it, but after talking with a neighbor (his house was built by the same builder) about his heat, I think I discovered that my auxiliary heat is either not wired correctly, or not hooked up at all. I've attached a few photos below.
Here is the programmable thermostat I installed. I connected the wires exactly the same as the thermostat I removed.
Here is the upstairs thermostat wiring connections:
Here are the connections at the zone controller:
From what I can get from reading the manuals for my components, the only way the emergency heat will work is if I manually flip the switch on the controller to "on" . It sounds like the heat will work in emergency mode only until I switch it back off. Shouldn't the auxiliary heat be wired to come on automatically if the difference between room temperature and the thermostat setting is more than 4 degrees or so? Does it look like my equipment was wired incorrectly? Should I call the pros in on this one?
