Hi,
I just picked up a Hayward Heat Pump For our Swimming pool, I was hoping someone could give me a few tips on installing it. Here is the model number we got. http://www.inyopools.com/Products/02200014058160.htm
I will include a layout of what I want to purchase insofar as the wire needed for this device and also a pic of the name plate on the device.
I'd like to know if the breaker 50 amp Double Pole is the correct size based on the nameplate. It is a little confusing. I would also like to know if the type of wire picked out is correct kind.
Lastly what size liquid conduit (whip) do i need to hold 2 thhn # 6 and 1 # 10?
Here is the layout of what I want.
I have a 50 foot run from my main panel to a junction box on the outside of my house, I was planning on using W/G NM-B Wire Black # 6/2
https://www.wireandcableyourway.com/6-2-w-g-nm-b-wire-black.html
I have a 65 foot run from the junction box above to the disconnect 50 or 60 amp box located by my pool. I wanted to use 6/2 UF-B Wire w/ Ground
https://www.wireandcableyourway.com/6-2-uf-b-wire-w-ground.html
From the disconnect box I have a about a 10 foot run and was going to run #6 THHN red and black and a #10 green inside a Whip. I think the total wire length would be a max of 15 feet from the disconnect.
https://www.wireandcableyourway.com/6-awg-thhn-building-wire.html
I also have to bond all this to my pool and pump and heater I was going to use a number 8
https://www.wireandcableyourway.com/copper-building-wire/bare-copper/8-awg-soft-drawn-solid-bare-copper-wire.html
Once again please advise on what I have here and I have included a couple pictures to help explain everything a little more.
Let me know if you need more information.
Thank You, Mike
Thank You, Mike
