I have an old (1980's) builder's grade bathroom faucet that I am trying to remove. I was finally able to loosen the nut underneath the sink but I can't get it off the valve assembly because the brass assembly below the nut is too big. There is still a nub from the copper tubing that connected to the faucet where I had to cut it off. But even without this nub I think the assembly is still too big to get the mounting nut off. I loosened it enough to pull the handle up, and I took off the handle but I can't see how I can unfasten the top to drop everything down through the sink. I am attaching some photos. The handle on the left is still tight so you can see how it was before I loosened it.
Please help.
Thanks, Mike
Please help.
Thanks, Mike
