havalife, They may have the terms mixed up. If they are purchasing a manufactured home, which is a double or triple wide, they can not change structure. If it is a modular home, they are built pretty much the same was as a manufactured, and still would not change structure, due to how they are built.OK back to the question , Can walls be removed? If it is a modular home then NO the walls can not be removed. A modulare is built and engineered by the room, rooms are added to the design and stacked to make a building.
