Re: Have heard there's a replacement refrigerant for R-22, equipmnt-compatible & chea
The replacements may be cheaper for the refrigerant but legally if you are going to use them you can’t mix them with the r-22. This means that in order to use the replacement you would have to remove all the remaining r-22, fix the leak, sometimes replace oil, schraders, and possibly metering device then evacuate and finally recharge. At the quantities in most residential systems I just don’t see the cost benefit.
Sent from my iPad using Tapatalk
