Which method is recommended for installing 3/8"engineered hardwood over wood subfloor,the flooring adhesive technique or the staple/nailer technique?
Also is the tongue side to be facing room ,ive seen both directions mentioned online.
And isnt the felt to be laid in the same direction as the flooring- with the joists,Ive seen it mentioned both ways, again.
Thanks for any info.
