I will be puting some new oak pre fab stairs on in the next couple of weeks; however, i have a couple of landings to deal with half way up the stairs as you make 180 degree turn.
I will be installing oak bullnosing pieces for the landings and prefinished tongue and groove flooring for the landings.
Questions:
1. Should I install the landing bullnose piece ( has a groove in it) first and then work off of it to complete my 4x4 landing?
The benefit of this would be the bullnose piece will be in the perfect position and I would not have to rip it to a thinner width; however, I would not be able to nail the tongue part of these boards to the floor because - in a sense I would be working backwards - Installing the tongue into the groove idea - rather than nailing down the tongue section first then sling the groove over the nailed down section.
2. Is it ok to glue down tongue and groove planks off of a nailed bull nosing piece? This is only for a 4x4 landing.
my situation: I dont have the tools to cut a new groove in the bull nose piece so for example if I work off a straight edged wall by the time i hit the front of the landing I may have to rip the bullnose piece to a narrow width and would not have the ability to use the pre existing groove section.
What should I do?
thanks
Questions:
What should I do?
thanks
