Hi All,
After a long new-dad delay and my own overdone and overbuilt subfloor prep (1.5" now, no squeaks!), which included sistering a joist, I'm nearly ready to lay the first piece of flooring- almost 2 years on! The flooring has been properly acclimated, to say the least. This room is my second hardwood flooring project- previously I did a transition-free single level house.
I have what I guess is described as a cutaway staircase (see photos and ignore the mess). I have stair nosing to place around the entire cutaway, at least as far as it will fit given the big awesome timber stringers. It should give it a really great look based on the little dry fitting I did. However, I know the room isn't square, and the cutaway is similar.
The added subfloor strength and thickness gives me options. The strength is a perk, I really just needed the height, but the flooring can now run either direction. The joists run parallel with the top stair and the window wall, and are supported underneath in the middle by a steel beam. There seemed to be a reason I couldn't run the overlay opposite direction, but now I can't recall. The seems are all covered by a huge margin and it's glued and screwed. I was planning to run the flooring parallel with the window wall to accent the room shape and the big brick hearth in the opposite corner, but I'm coachable and overall quality is the goal. I could use some input here. The wall of windows near the hearth is the long wall.
The real question is, where do I start laying the flooring?! Should I give preference to the walls or the stair cutaway as far as square? Should I do the cutaway and then work outward? I expect I'll have to rip cut flooring around the cutaway and the walls no matter what, but best practice takes precedence. There will be angles. Joy! Could or should I rip cut the nosing if that saved some extra finagling somewhere else? I'd rather not destroy any expensive nosing, but I have extra and that said, if the best suggestion is something other than the nosing, then I don't mind not using it either. I want to do it right.
Details:
3/4" x 3.25 oak hardwood flooring and stair nosing, prefinished
Doubled up 3/4" plywood subfloor (1.5" total thickness).
I appreciate your help!
Details:
