Hi All,
I had tried posting this problem at another forum, but didn't have any luck. Maybe a DIYer at this board can. (cross my fingers).
Here it goes:
We recently opened up a closet area which didn't have hardwood installed on the floor. As a result, I have the dilemma of trying to transition HW flooring from a room that has already hardwood to a section of a room that doesn't have any (the closet).
So essentially I am trying to add additional new hardwood to an old room that already has some installed.
This pic below explains it better.
How would you handle installing/extending new hardwood to a section that doesn't have hardwood flooring installed, but is adjacent to a section that does have hardwood floor?
I'm trying to make it as seamless as possible and avoid having a line (shown in red) appear at the opening.
Thanks for your help!!!
Ron
The correct way to fix that is to weave in new with the old. Some of the old will have to be removed back to the last joint, or some point where you can make a straight cut, then insert a new piece that ends at the step/wall. That eliminates the straight line you would have if you just added to what is there now. It looks like you have random width flooring?? That could be hard to match.
Thanks for the response, Bill.
Luckily the planks are all the same width, it just doesn't appear in the image. The challenge is finding the old 2 1/2 width planks to match.
It looks like I will have to treat the job as if I were replacing a single planks here and there.
Ron
it would of been so much easier if the floors ran the other direction. but as bill said you will have to cut each coarse back a bit so the seems dont all end up there. random joints to make it look the best.
Or you could run a threshould there and have the flooring build off the threshold. Might look ok since you have the door csing right there.
Thanks for the help! Seems like it'll be some work chiseling out the odd plank to weave the new ones, but I think the final product will work out better.
If I'm placing a new plank in between some old ones, I'm guess I will have to use glue to hold it down? There won't be enough space for staples...
